Format HDD without deleting a folder
16 Nov 2011
I have two SSDs in RAID. it might be a long shot, but is it possible to format the drives without deleting Steam or maybe a way to restore it later, as I don't want to put unnecessary write cycles on the drive.
the steamapps folder can be backed up before re installing windows and then copied back over and add the folder back in to steam.
I have all my steam games installed and the steamapps folder backed up to a external hard drive so if I do format I just dump it back in to the same location as before once steam installed.
Same process used here. I've backed up my steam & origin directory onto my NAS.
He said to avoid writes so backup isn't an option.
The best way I can see is to erase all the other data on the drive then shrink the partition to only include the steam data, create a new partition and install to that then just use steam as if its on another drive.
You would need another PC or some bootable software to do this.
Personally, I've got an SSD just for Steam, I mark it as the S drive :D
If anyone else wants to set a steam drive icon, download these and put them in the root of your Steam hard drive.
autorun.inf
steam.ico
You can set them as hidden files.
Need to reboot for it to take effect
Looks neat in Explorer
I honestly think you'd 'waste' more writes faffing about trying different solutions than if you just reformatted or whatever.
I wouldn't worry too much about it personally.
