Formatting >1Tb
Man of Honour
4 Nov 2002
West Berkshire
I have one of these behemoths. They have a capacity of 1.5 TB or 1.36 TiB.
However, when I try to format it as a single giant NTFS partition, the format stops at 73%, or if I do a quick format, a later chkdsk stops at 73%. 73% of 1.36 TiB is 1.00 TiB. I suspect that's not a coincidence.
The drive itself is not faulty - I can read and write every single sector all the way to 1.36 TiB. It's just Windows/NTFS that doesn't want to know. Microsoft claim a practical limit of 2.00 TiB for NTFS (and a theoretical bigger limit), so it should be fine.
Is this a known problem? What am I doing wrong?
That's odd, NTFS should handle that easily - I've got a single 1.75Tb partition here, no problems.
Did you change the format settings away from the defaults?
Shouldn't need to, mine's formatted with the defaults.
What's the OS, XP? Basic or Dynamic disk?
EDIT: You're not alone in having this problem, there's a customer review on Amazon where a guy describes exactly the same symptoms. He ended up returning the unit and getting something else :(
Tested on two machines - one XP Pro SP2, the other MCE 2005. Also tested both USB and 1394a. Don't have 1394b. Same each time. Listed as Basic, 1397.27 GB.
I don't know enough about disk mechanics to konw if the last 2 weeks of solid formatting/verifying will/could do any harm. Assume not.
OK - I split the disk in two (logically, not physically :p) to see what would happen. Formatting two 700GB partitions shouldn't be a problem. Right?
Wrong. It gets to 300GB and hangs.
I'm thinking there's a chipset limit somewhere as both systems that have problems have old intel i865G chipsets in them. I have no idea why this should be so, but I'm running out of other options. I'm not turning up much on Google so I have little evidence to help prove this, or find a workaround.
Edit - I was able to confirm that it's a hardware problem by creating a 64MB partition at the end of the disk. Quickformatting the partition works fine, as does reading/writing data, but if I try and do a chkdsk it reports every sector in the partition as bad. I wonder if Windows has a problem accessing sectors beyond 2^31 (2,147,483,648). Wouldn't surprise me (that number pops up surprisingly often in programming).
Google doesn't turn up anything though. Anyone got any more suggestions please?
