formatting and partioning questions
7 Nov 2009
hopefully this will be the last question i ask about the mac :)
recently i partioned the main drive setting up bootcamp, is there a way to un-partion the drive, as I won't be using bootcamp i much prefer to use VM now I have 100GB of partioned space going unused.
Also, what is the easiest way to format and restore OS X?
In Bootcamp you can remove the partition I believe or you can open Disk Utility and delete the partition.
Boot off your OS X CD, when you get a menu bar at the top, go to utilities and then use Disk Utility to partition it fully with a single partition, you can then run through the install procedure.
/edit - This should help.
