Formatting? HELP
10 Feb 2013
West London
heres what i have
ARCTIC FREEZER I30
G.SKILL RIPJAWSX 16GB (2X8GB) DD
SEAGATE 7200.12 1TB 6GB/S
SAMSUNG SH-224BB 24X DVDRW OEM
INTEL I5 3570K RETAIL
GIGABYTE GA-Z77X-UD3H MOBO
GIGABYTE AMD RADEON HD 7970 OC
ZALMAN Z11P CASE
XFX CORE SERIES 650 WATT PSU
can someone tell me how to fully format my computer i also have windows 7 64 bit
please
THANK YOU
I'm going to assume you want to format and reinstall windows. As PC initially boots hit the delete key a few times until you're in the BIOS. Use the arrows and enter keys to navigate around until you find the boot order. Ensure the the DVD is set as the first boot device. Open the DVD and put your windows disc in. Reboot PC and follow on screen instructions.
That's it.
Then use a genuine CD
Not necessarily, I just had this when installing XP onto an old system. Luckily I had used my original XP disc to create a slipstreamed disc, incorporating SP3. I started install but got file missing error, so I switched the slipstream to original XP, installed a few files then got same error, I switched disks again and also again later and install went fine.
Main point being it doesn't mean he is using a dodgy copy cos he got this error.
