Forum Software
Man of Honour
17 Nov 2003
Southampton, UK
So this is a two part thread:
Firstly, if you have ever administered a forum what software is your favourite from the admin side?
Secondly, what is your favourite software to use as a regular member?
Just trying to gauge what software to use on a new non-computer based forum and seeing if a vBulletin licence is really worth it.
I do quite like vBulletin for both sides.
I've used MyBB and IceBB in the past but none are as easy as vBulletin.
Just my 2p worth!
M.
I've used Jforum a bit, set it up whenever I've needed to have a forum for a site. It's quick, easy and does everything I need it to. The admin levels are good and there's a fair bit of control you can apply to posts if you want to, for example, if you wanted to moderate/vet all replies so they are not shown automatically, it can do that.
I like vbulletin but the price is prohibative. For large user board i would spend the cash for smaller to medium I would go with phpbb.
I admin and regularly post on an Invision board and its quite nice, does everything that I want from a forum.
I do like vBulletin from a user point of view though :)
I've used at least a dozen different ones over the years (as an admin), and vBulletin has proved to be the best by far.
And vBulletin version 4 is just around the corner, so stick with it!
vBulletin is light years ahead of anything else ive used. phbb and mybb are good alternatives but from both a user and admin point of view you just cannot beat vBulletin. by far the best option. only downside is that you have to pay for it obviously.
I have tried a few over the past 6 years and Vbulletin always comes out top for support, quick release of bug fixes and ease of use.
The Vbulletin admin panel is a little overwhelming at first if you have been used to something like PHPBB but you soon get used to it.
Although, it largely depends on how busy/important the forum is. If it's relatively small, it's probably worth starting out on a free board (SMF) and then switching to vBulletin when things 'warm up' a bit. vBulletin is easily the best, but it's certainly not worth the money for small boards.
Vbulletin = £5 per month
Nothing in the grand scheme of things especially if you have a reasonable size community.
