FPS double screen refresh rate
3 Feb 2025
Kilmarnock
Hi all, recently moved from console to PC gaming and getting used to manually adjusting settings, spent most of yesterday playing with different resolutions and FPS.
Using Afterburner OSD, I found my temps were lowest when i set all FPS options to 120 FPS which is double my TV`s refresh rate of 60hz, when set to 60hz to match the screen the temps were higher
Are there any drawbacks to this 120FPS setting
Normally lowering the FPS would lower the temps as its having to do less.
What temp was higher when using the 60 FPS?
If your screen has a max refresh rate of 60 anything higher is normally a waste.
All cpu & gpu was higher, temps and usage, I have found that I get even lower temps with V sync turned on, I have read it causes lag however if it does it is barely noticeable to me and I am still getting kills at the same rate, so it seems to indicate there is no real lag
Is there any downside other than lag to using V sync ?
