FPS - in game settings
14 Dec 2017
Aberdeenshire
sorry if this is the wrong section but I’ve been looking for a thread that was created a while back that was really good that went in depth about FPS,gsync, in game settings, pixels etc. Like a general walk through of everything and how to make each thing better by using certain settings. But I cannot find it anywhere. Needing to have another read to confirm something that’s been annoying me in all my games lately.
Mainly gsync with my 120Hz screen.
Can someone point me in the direction if anyone else has seen it.
since when did gsync=gay culture :o my bad, well my question did get answered so can’t complain. Last time I create a thread on my iPhone
Sent by iPhone
Thought this was GD then, but I'm in PC Games. David you have the same lappy don't you, have you got a 120Hz monitor or are you referring to a lappy?
Yeah we have the same, that’s right I’m referring to my laptop I got the 120Hz one. I sorted out my last problem of the cpu usage but now I seem to get stuttering like my games will slow down for a second and then speed up all of a sudden like trying to catch itself up,
It’s not so bad with gsync off but still happens now and then, Was wandering if when gsync is on does that lock the FPS to the Hz of your screen? as it goes lower sometimes down to like 70-80. Even get stuttering when I drop down to high instead of very high or ultra. Even when there’s a GPU usage gauge hog would use say 5gb of vram out of my 8 but still get stuttering
Was trying to find the thread I mentioned above as I forgot to follow it and was interesting.
Maybe I’m playing to demanding games for 120Hz?
*Mods can move to correct place if needed*
The laptop doesn't have Gsync, the screen is capable but due to the way the GPU goes through the iGPU it doesn't actually have operational gsync.
Sorry sorry! I’ve been meaning vsync, think I’ve been reading into to much things lately and getting mixed up!
So know I know what I’m talking about.... when you turn on vsync is that meant to lock your FPS to 120 to match the Hz. Could I have to turn the Hz down? Is that pisssible? I run most games fine just a few that stutters
Wildlands - I know that’s quiet a heavy game but even stutters if I turn everything to high which uses 3 out of 8gb.
Pcars 2 - only seems to stutter in bad weather I have settings to high on this to which doesn’t stress my GPU out.
Steep - stutters now and then again have settings down.
Thought being i7/1070 I would be playing smoothly but even on high instead of ultra or very high I’m stuttering surely I don’t have to go to medium?
How good is NVIDIA experience at picking your settings for you I’ve tried opening games through that to
I get the odd stutters, Destiny 2 gives me stutters, not sure why. As of late with Windows updates and NV drivers it's causing some stuttering
So do I have to disable vsync in my settings in game for all games?
I was getting bad stutters in f1 2018 until I turned off vsync seems a lot better now
Silly choice of monitor
(desktop is freesync monitor v 1070ti)
Freesync and Gsync lock your screen refresh rate to the frame rate of your GPU. But vsync does not do that...
First let's start with vsync off. When vsync is off then the GPU will produce frames as fast as it can and they will be displayed as soon as they are ready. Sometimes these frames are ready to be displayed when the screen is it part drawn. So you end up with a very slightly different picture being drawn part way down the screen. This is called tearing. You get the fastest possible frame rate but the screen 'tears'.
If you turn vsync on then the GPU will wait until the screen is ready to draw a new frame before it renders it. It will look much smoother but can result in slightly lower frame rates and also some input lag. The combination of these is probably what you are seeing.
Freesync and Gsync are technologies which allow the screen to display the frame as soon as it is rendered rather than the GPU waiting.
It sounds like you do not have freesync or Gsync. So if you are getting very poor performance then you should try disabling freesync in those games. You will get some tearing but the game will probably run at a little higher frame rate with less input lag.
Thank you that explained a lot, what it is. Is that I have a freesync monitor and a NVIDIA GPU does that make a difference to what your saying?
I know that as much but having a freesync monitor with an Nvidia card do I have to disable the vsync or shouldnit be better as I seem to get better results with it disabled I usually like to keep it on for quality. Not sure if it’s mucked up because I bought this monitor
I have a FreeSync monitor, you can still use Vsync.
I do wonder if the stutters are something to do with the Nvidia Optimus or whatever it is, as the stutters I get on the laptop screen are not present on an external screen. Saying that No Man's Sky had the issues until disabling VSync but that was wider known.
