Pc spec
amd64 opteron185
2gb corsair ram
x1950pro
10000rpm HDD
Fresh install of windows, downloaded all the latest drivers for everything.
The problem
i like to play old games like half-life mods, i.e CS
Since i did the fresh install my fps is really bad!
if i look at a wall it will be 99fps, but as soon as there is more then 1 person on screen the PC instantly brings me down to 60fps, and once on a 32player server it brought me down to 16fps.
i know this should not happen.
my old setup with an amd3800+ and an x800pro could run CS flawlessly with about 100 smoke greandes on the floor.
when i upgraded things were better on more demanding games like TF2, but after the fresh install everything becomes slowed down and really annoying. thinking of reformating again, but just wondering if anyone else has any ideas.
oh, and when i boot up it tends not to load anything for a minute, then it suddenly loads everything in 1 go.
ive defragged too using a tool called o&odefrag version 10.0. i personally would have thought this pc could handle a simple game like cs1.6 even if it had all the problems in the world! but seemingly not :[
any suggestions? ive done all the usual stuff like getting rid of all background / systray apps etc. but i do also have a duel core and even when i had a single core it could do things perfectly fine on 1.6 with about a million applicaitons in the background. so as you can see i am a little concerned!
apps tend to load up a little laggy as well.
amd64 opteron185
2gb corsair ram
x1950pro
10000rpm HDD
The problem
