The 1st image shows the back of my case and the wiring back there, you will see a few cables there some are the regular power cables and some are fan cables, also the bottom right there is 3 fan headers there that is actually the cpu coolers fan headers that are left over from the akasa 5 fan pwn cable, I don't like to power my fans from the motherboard even the cpu fans because they sometimes can take out the motherboard.
This image shows the daisy chain fan cables I have that are used to power the front fans on the case and there is one also powering the 180mm fan there and also another to the back 140mm fan too just they are under all the other cables hidden from view.
The side of the case with the components. Just a note all my fans for the case are powered via 12volts, even the fans that cool the ram there. Only fans controlled are the Yellow akasa viper fans via the pwn cable that is attached to the cpu header but does not take power from there just the RPM of the fans and PWN control to speed up or slow down the fans as needed by the cpu.
I used this cable to power my CPU cooler fans, it has PWN control and takes the power from the PSU not the motherboard CPU Fan header. (Note make sure to use the fan header cable that has four cables to one of the cpu cooler fans and any of the others to a 2nd or 3rd or 4th or 5th fan for your cpu cooler, there is only one fan header cable with 4 cables easy to spot from the other 4 that only have 3 cables on them).
Akasa FLEXA FP5
Supports 5 PWM fans from a single motherboard header
http://www.akasa.com.tw/update.php?...ype_sub=Fan Cable Adapters&model=AK-CBFA03-45
Changed the CPU cooler to the Thermalright Archon CPU Cooler, I was planning on water cooling but tried the Corsair Hydro H80 High Performance Liquid CPU Cooler (What a bad joke that was, it sounded like a jet engine and all sorts of funny noises it made, so went right back and was no better at cooling than my Zalman CNPS9700 NT that I originally had). I should have known better then to trust corsair with their fans that rattled on my ram cooler from day one and got worse, so had to replace the fans on the ram cooler too, to quieter and better spec fans. Corsair RAM and PSU that's all i'm ever going to buy from them from now on.
Also to add my system noise level is great and even in the quiet of the night and no other sounds it just really humms gently with fan noise that is really the air whooshing nothing that disturbs me or my other half and the cooling is as good as it will ever get on air for such a case, so very happy with it
. I can't deal with noisy systems anymore, this was the reason for the case change in the first place and now i'm done fiddling with it and enjoying using it more now then ever.
I also found this cable for powering case fans from the PSU instead of the motherboard headers : NesteQ 12V / 5V 3 Pin Fan Power Cable
I would have got that if I didn't have the fan power daisy chain cables I used. This cable allows 3 x 12v fans and 3 x 5 volt fans to be powered, so if you want to power all fans at 12 volts as I do, you will need 2 of them because there is 5 case fans. They are cheap cables £2.65 ish and look nice it seems.
http://www.nesteq.net/gb/products/cables/nsk1205/
