Fractal design LED
27 Aug 2009
Hi guys. I have just built a new system with a Fractal Design C case. Great silent build, but appear to be having a bit of an issue with the Power LED on the front.
There is cables coming from the font panel for 'Power LED' and 'HDD LED'
The Power LED cables appear to do nothing no matter where I plug them in, no light at all.
The HDD LED however works fine when plugged into the HDD socket, or as I have it, in the Power LED socket (so there is a solid power light instead of a flickering HD light).
I this normal? Is there only one LED on the front panel? And if so, what is the Power LED cable for?
Thanks
