- 1 Sep 2023
- bristol uk
Hi i am looking at getting a pc built with the below ruff specs.
Fractal north case
7800x3d cpu
rtx4090 gpu
32gigs ddr5 6000mhz
2tb nvme drive
x670e mobo
now i wanted o spec a it with a 360mm cpu cooler, but i am finding mixed signals over you tube ect with regard being able to fit a rtx4090 and a 360mm cpu cooler in it ?
is it possible ? I have had someone say you can only fit certain rtx4090 cards and only a 240mm cpu cooler ? Just want some clarification on this really, any help would be great.
Thank you
Fractal north case
7800x3d cpu
rtx4090 gpu
32gigs ddr5 6000mhz
2tb nvme drive
x670e mobo
Thank you
