Hi all
I'm putting together a new gaming PC for my son in a Fractal Design R3 case.
I might do a mild overclock on it, I've got the following:-
Freezer 7 Pro v2
i5 3570k cpu
16gb kit of Corsair Vengeance LP DDR3 ram
XFX HD7870 gpu
256gb Samsung 830 SSD
Asrock Extreme4 Z77
As I've never done any gaming myself, I was wondering where would be the best location for the extra 2x 120mm fans I've got, to get the best airflow! Was going to put one on the side but do I have it blowing IN onto the gpu, or extracting the warm air from around it? Also, I was going to put the other on the front to go with the supplied one, but would I be better off siting it on the bottom/top of the case?
Thx for any advice....
Freezer 7 Pro v2
i5 3570k cpu
XFX HD7870 gpu
Asrock Extreme4 Z77
