frame rate drops
Status
Not open for further replies.
30 Sep 2014
So i've never pc gamed in my life and just thought id try it out on my laptop since i got a new monitor. i tried to play lord of the rings conquest which came out in 2009. i used to play it on 360 years ago. im having frame rate issues a lot and my laptop heats up a lot after about 10 minutes of playing it. i did turn off "wait for v sync" or something and the frame rate improved though.... but i figured i wouldnt need to do anything like that because my laptop is supposed to be powerful enough to run the game. i basically just want to know if it's not powerful enough to run it. the specs suggest it is so im confused. and if it is powerful enough to run it.... what could be messing up the performance of the game or how can i improve it? here are the specs it says it requires...
System requirements:
Processor: 2.4 GHz or faster; Intel Core 2 Duo or faster
Memory: 2 GB
Video: 256 MB compatible with Shader third model
Sound Card: Sound device compatible with DirectX 9.0
Free space on hard disk: 6.2 GB
Here are my laptop specs:
HP Envy M6-1310sa
15.6 in 1,366x768 display, 2.4kg, 2.5GHz AMD A10-5750M, 8.00GB RAM, 1,000GB disk, Windows 8, built-in AMD Radeon HD 8650G graphics processor
heres a link to a breakdown of it also: http://www.expertreviews.co.uk/laptops/1303267/hp-envy-m6-1310sa
Can anyone help me out? Or maybe direct me to somewhere where i can be helped? Would greatly appreciate it if so. Thank you.
Status
