Freecom DVB-T USB Stick
28 Dec 2002
UK
Hi, does anyone have the Freecom DVB-T USB Stick working under vista 32bit?
If what did you do to get it to work?
Thanks. Chris
EDIT: working fine with BDA drivers from freecom site, and windows media centre in vista.
hey mate i got it working with media portal but not media centre.
I get to picture with media center, how did u get it working?
cheers
I didnt do anything special, I installed the BDA freecom drivers, ran media centre followed the setup TV wizard and it works, well i thought it did, but for some reason only bbc 1 and 2 work.
It found all the channels in the scan but nothing else works.
Have you got all channels in media portal?
Thanks
Check my post out a few weeks back now http://forums.overclockers.co.uk/showthread.php?t=17687793
Ive emailed Freecom and they arnt developing drivers for Vista :( looks like a new usb/pci TV card is in order, or try Mediaportal as suggested or dual boot with XP MCE like I do, bit of a pain :p
Edit: A bit more info it seems Vista MCE uses different frequencies for the channels which is why it doesn’t pick up any other channels apart from BBC1 & 2
