For instance, CSGO black screen startup issue with freesync enabled
i disable it and it works, so seems there is a issue with this game, you would think there wouldnt be a issue with this game.
Tombraider - even though freesync seems to be working
i disabled vsync in CCC and enabled freesync selecting native @90hz and it shows its working but and smooth but i can see places if i move fast from left to right that there is screen tairing and this should clearly not be happening.
here is a question also about vsync should it be disabled off for everything or on for everything ???? if i enable it my frames stay @90hz and in tombraider there is no tairing anymore and very silk smooth does this mean im using normal vsync or freesync or does freesync work with vsync enabled ? very confused lol
