Freesync with nvidia card yes or no?
6 Nov 2018
I run a GTX 1080 with an I7 7700k. My current monitor is an ASUS VG278HE 1080p 144hz TN. I am currently playing AC origins at ultra settings getting framerates between high 80's and low 100's. I do not see any visible tearing or stuttering. I am getting a new monitor and am aware of the Gsync offers by ASUS and Acer but none of them are curved (I just like the look of curved and I dont have the real estate for the ultrawides). I definitely want 144hz 1440p Ips/VA. i am inetrested in eyecandy and only play RPG's such as witcher and ESO. I have seen the below monitors that encompass what i am looking for but they are Freesync. Is there going to be any noticeable artifacts during game play and will I still get the same framerate?
https://www.pccasegear.com/products...q-qhd-144hz-curved-rgb-27in-va-gaming-monitor
https://www.pccasegear.com/products/43096/msi-optix-ag32cq-32in-curved-qhd-144hz-va-gaming-monitor
https://www.pccasegear.com/products...d-hdr-144hz-freesync-27in-qled-gaming-monitor
Thanks for any help.
Best you'll get is 144Hz, normal mode.
Thank you for a response I appreciate it. I not quite sure what that means I am aware of Gsync and Freesync differences But I like the look of the Samsung and MSI monitors and the reviews I have seen. Just worried about artifacting and framerates. I could get the PG27VQ from Asus that has Gsync but its a TN panel Am I over thinking this???
Cheers I am currently running a 27" Tn 1080p 144hz monitor with no adaptive sync and getting between 80 to 100+ frame rates and no issues I just like the monitors with better eyecandy so will bite the bullet and probably get either the MSI optix MPG27CQ or the samsung Thanks again
If you can't hit 144hz you will get tearing and lines left to right all over the screen.
to have no artifacts between 80-100fps you need a monitor with at least gsync and 100hz refresh.
