Freeview pc card
Sorry for asking a question in your thread but, what's the deal with these cards anyway? Do you just plug in an aerial, install the software, and you have freeview on your pc?
pretty much, the USB card I have will even detect Sky-Boxes or video players if they are connected between it and the house antenna :D
Haupauge are good so are the ones OCUK sell only slight negative with teh compro cards is that the remote is a bit of a brick.
Are the two listed above not for use with a dish only?
They appear to be yes.
I've got a T500F (normal terestrial or digital via a normal aerial), it's fine for my needs, though I've never been able to get it to record sound (use iplayer or 4od instead), and media centre doesn't seem to like it (which is fine because I hate the way mc takes over the o/s). I just use the latest update of the compro software which seems fine to me.
