The fan on my Freezer 64 gave up - as they do
So I've attached a YS-Tech Silent 80mm fan instead; it is no noiser than before.
Temps are 29C idle and 44C onload, which is exactly what they were with the original fan. I am pleased with the result, but I bought a freezer 64 pro to replace it - I might just try it to see how much better it is.
Pic of the mod here:
And yes there is a 146 under the freezer!
.So I've attached a YS-Tech Silent 80mm fan instead; it is no noiser than before.
