Freezing for no reason? Any Help?
Hi there, i've cleared up most of my PC problems thanks to these forums, but another annoying one has just occured......
My computer keeps freezing for no reason, it will stay on the windows screen and i wont be able to move the mouse, use the keyboard anything, its as if someone has taken a printscreen and left it there
This can happen at any time, i thought it was an airflow problem at first so i cleaned my hsf and left the side panel off and got my cpu temp down 20 degrees(crazy i know).....
The only option for me then is to reboot the computer via the reset button. It just happens at random times, sometimes after being on for 30 minutes sometimes after being on for 2/3 hours, and i don't necessarily have to be doing something either, it could just be idle!
thanks in advance for any suggestions.....
