Fresh install of xp?
11 Apr 2008
Orkney
hi my m8 got a problem with his pc so he formated,since then his cpu usage is allways 100%. Ive took task manager up and went to process theres nothing there that is using 100% of his cpu,hes formated 2 times now and its still the same any idea`s what it could be and how to fix it?
Ye it was the same problem it just started few days ago,but it was running fine he didnt change anything it just started doing as i said above 100% usage,so he formated hoping it would solve it but no its still there.
Sounds like it might be a rogue driver or something. Does he have the latest official drivers installed for all his hardware? Did he install any new drivers before it started going slow?
When you are looking in task manager at the processes, there should be at least something showing high processor usage, even if it's System Idle Process. Are you sure there are no hints there?
No mate the system Idle is 99% the rest is on 0%,mines at the moment is 99% which is normal but my cpu usage 0% his 100%.
