- 25 Mar 2006
- Thornbury
i have just managed to set up a dual boot config on my girlfriends vista laptop, i have got all drivers installed successfully, however its not finding my wireless network.
i can boot into vista and it sees my wlan ok and connects fine, if i boot into xp it does not find any wlan connections and the drivers are installed for the device. in xp i can use the nic on the laptop to connect to my network no problem.
any idea what i need to do to get the xp install to see my wlan
had the same problem at her house could not see her wlan either
cheers
cheers
