- 7 Jul 2010
Really? I've never had a dead motherboard and/or CPU before so I have absolutely no idea.
Any specific way of testing?
Not really, without another CPU.
Have you tried jumping the PSU?
if you were closer would have helped you out bud![]()
is the cpu located the correct way on the mb which way is writing on the chip
Might be a good idea to have CPU tested before you return it to seller.
unless your wanting to post the cpu down and i can test it and post back to you![]()
have you done a full cmos clear? leave mb battery out overnight and then try
damm that sucks, hope you get your money back.
Not yet! I have had the cmos battery out for a few mins at a time but I'll go take it out just now to make sure, the manual clear for the cmos is via a jumper of which I don't have
Edit: Motherboard manual says just to touch the pins with a screwdriver!
