benjo said:I wouldnt say so, but you should be looking forward to having more than 8Gb~ to play with
edit: Sound wise, it will probably be quieter. I'm guessing that 12GB is quite old? The newer drives are getting more silent
Justintime said:Strongly believe he means 120Gb, dunno much 12Gb 8mb cache drives![]()
But if he did, then ignore anything i just said
benjo said:You never knowBut if he did, then ignore anything i just said
benjo said:See, this is why i dont usually venture into the HDD forum. Goodbye for a few months![]()
