From XP to 7
12 Mar 2008
As a longtime XP user I was wondering what the advantages would be if I was to upgrade to Windows 7. Would there be any need?
It would be part of a new build including an i5 760, 4 gig or ram and 460gtx, mostly for gaming.
Cheers.
In short, yes, you should upgrade to Windows 7. It's a more secure OS, and in my opinion has a much better user interface, and unlike Windows XP will take full advantage of your computer's hardware. There are many threads like yours in this forum, so if you search, you should fine some more information.
Well you'll have to get Windows 7 as you'll be severely crippling your system putting XP on it. There's no point having 4GB of ram if your operating system can't even address all of it.
XP doesn't support DirectX 10 or later. I think XP 64bit was more of an afterthought and you'll need 64bit to make the most of 4GB RAM. Also, you can't fault the spinny Windows 7 logo during start up!
All of the machines I've used W7 on, including VMs, make XP look slow. If your XP still runs faster, something is wrong or your hardware is not up to the job
It not that XP runs faster it is just that it is far faster doing certain jobs
Stuff like opening a explorer window , xp opens windows shows contents within a second
Win 7 same folder same hardware takes 6-7 seconds to open and display contents
Copying files from network , under xp a sample file will take a couple of seconds
win7 takes about 4 or 5 times longer to do the same thing
But win7 has a much crisper cleaner looking GUI , which my my opinion is far more
important than performance of the file system
Win7 is great at running multi threaded apps , defo faster than xp ever was
That would be Experiences , plural , currently trying out several win 7 machines
on a corp network ....
And this is applicable why?.. Sort the corporate network out, sounds poorly setup. He did say:
mostly for gaming.Cheers.
Never had either of those issues on any of my Windows 7 PCs. Sounds like your AV is slowing it down.
My experience for day to day stuff like browsing the internet, word processing, office stuff, is that XP is faster. My 4-5 year old PC, 5 year old laptop and 1 year old work laptop are all faster than the two new laptops running Win 7. I find it very frustrating.
7 seconds to open a folder?! Definitely something wrong. My Win7 machine opens folders instantly, just like it did on XP.
Is this quite low-spec hardware that's been upgraded to 7? A lack of RAM in particular will make 7 feel slow compared to XP. A system with 0.5-1GB will do basic stuff pretty well under XP but will be a dog under 7. Once you get more than about 1.5GB in there, 7 will be at least as quick.
Make sure you get Windows 7 x64.
Emphasis on this. As already stated you won't be limited to 4gig or less + what would be the point of buying a dx11 capable 460 if you're gonna limit yourself to xp & it's dx9?
Did the same move on my last build & wouldn't go back...the whole thing just seems more stable. However I still get lost with the new interface & wish I could have the old one back...maybe that's just me tho.
One thing I noticed & missed when I installed win7 was the absence of outlook express. Ended up downloading Mozilla thunderbird as a replacement instead as it's similar...However there's a new download "windows live essentials" which I think covers this anyway tho not tried it myself...
Anyway...no point in building a new pc & then hampering it with a ten yr old operating system.
I admit that I do still have the occasional moment where I try to do something how I'd have done it in XP or Vista. But I think it's down to sheer force of habit after nearly 15 years using the old Windows taskbar, rather than because the old interface is better!
