Front brakes spongy even after bleeding?
Maz
Maz
18 Oct 2002
Newcastle.
The front brakes on my Kwak ZX7R are really spongy!
The bike has braided hoses and I bled both sides using a vacuum bleeder last week and the brakes feel spongy!
Am I missing anything obvious?
I'm going to make sure all the unions are on tight, brake pads are a bit low but I wouldn't have thought that would have caused it.
Any ideas?
air in the lines. sometimes you have to take the caliper off - wedge a big screwdriver in the pads (so the pistons wont pop out - big job if you mess that up! lol) and hold it upside down to bleed it right!
had to do that on a GSXR1000 K1 as the caliper bleed nipple isnt 'quite near' the top of the caliper so some air can be trapped in!
Cable tie trick normally works a treat. It's do easy to let air in bleeding the brakes, even with a decent kit.
Also make sure you pistons move freely. I strip and rebuild mine every 5 months. 1 hour job when you have done it a few times.
My brakes are a pain .. 4 pistons 4 pads .. (brembos) i normally have have to take them off and hang them upside down with a lump of wood between the pads . once there bled i normally have to zip tye the lever back for a day . if you have sliding calipers its worth stripping and cleaning them
There isn't a bleed nipple at the cylinder end, they are Toxico 6 pots and 2 of them.
I'll crack the end off the master cylinder and wrap a rag round it and give it a squeeze, see if that makes any difference.
But I have a pneumatic vacuum bleeder which I use at my garage, this is what I used to bleed it.
Done the clutch aswell, and the clutch feels just fine!
Yep do exactly that. Also tab all around the lines and MC/Calipers with a rubber mallet to try to move any bubbles
Tokico`s are fantastic if you can bleed them properly..
On my TLS standard front end I fitted an RSV mille 1999 master cylinder and Tokico 6 pots...Wow..fantastic.
Now got Gixxer k5 front end on with radials, and the Mille master cylinder... Ferrodo Sintergrip (STAC) pads and I can brake insanely fast, Michelin Power Ones help too...:p
http://www.braketech.com/index.php?option=com_content&view=article&id=63&Itemid=94
Wont ride with anything else now.
Been at this riding lark for about 24 odd years and when I preach, its for real..:D
Revo.
The 6 pot Tokico's are notoriously difficult to bleed correctly for a firm lever.
I have found that the tie wrap on the lever overnight after a proper bleed helps no end.
Go very slowly on the bleeding as well, it's very easy to get even a slight whiff of air in there.
True, very true.
