Front bumper respray
Take it to a main dealer they will get it looking better than this but still not 100% as no way to apply the same level of paint as the bodywork on plastic as it would take forever and needs week to dry between layers!
hmm not all dealers are even that competent.. daughters zaphira came from a dealer down country bristol way i think, she noticed the bumpers front and back were tatty (4 year old car) so haggled for them being repainted. yes no problem there bodyshop would sort it ...main v/x dealer..when i looked at the car a couple of weeks later they stood out like yours like chalk and cheese. i put it down to me being colour blind , but now even her next doors asked if it had been in a shunt...
you may think you can live with it but trust me it will annoy you over time . best get it right now rather than later.
Now, he was honest and said plastics do not match 100% and it did look off. I got the feeling he didn't want to repaint and wanted to blend in.
He's correct that high metallic paints can sit differently on plastic, but blending out won't help that.
What blending will help is if he's not used the correct colour, which I'd say is what has happened. If he's bought the paint in as you say, he'll just have gone for the standard shade rather than one of the variants. As some have mentioned, a lot of us bodyshops now have doodads to scan the existing paint (photospectrometer), which, along with software can narrow down to a much closer colour match. It can then be further tweaked by eye if really necessary, but computer matches are generally more than acceptable to most eyes.
If he buys his paint in, it's unlikely he'll have his own paint scheme/software/scanner, so that option is unavailable to him. It sounds like he'd rather flick the paint he has left over into the adjacent panels to disguise that fact that it isn't quite right.
I can sympathise with him a little as our job is a nightmare with some of the fancy modern colours, where everything from air temperature, humidity and application technique etc etc can alter the shade a little, but it helps a bunch if you start out with the right colour!
As a possible solution, see if his paint supplier has the necessary equipment to scan your car for a better match. It still won't guarantee a 100% invisible job, but it ought to be much closer than that one, which simply isn't acceptable in my opinion.
If they had to blend in the wings and bonnets surely they would then have to blend in the doors and all the way back on the rest of the car
No - that's a full respray.
You generally just blend to the joining shut line.
Vauxhall's were this bad from the factory. Famously so.
taken from https://www.astraownersnetwork.co.uk/threads/bumper-colour-question.113782/
if you were on a PCP , you wonder how you pre-qualify the paint shop to do the work - or, you have to use the manufacturer ?
and what colour tolerance pcp company accept.
Thanks for the in depth reply.
I have lived with it for a week now and due to extra costs I will just leave it (even though it bugs me).
Advice for others - get an oem bumper!
