- 26 Nov 2009
I don't understand.
That washer looks like its got a flat edge, cant you spin the round to the frame side, looks like it might fit?
The washer is curved to fit around the curved metal part which the derailleur sits in. You can see in the photo that the weld covers a large part of the curved metal so the washer wont sit flat against it.
I would either file down the curve of the washer so that it fits around the weld or turn the washer 90 degrees so that it cant slip round.
I doubt that Decathlon would be able to fix it. The only way they can resolve this properly is to give you a new frame - which isnt an unreasonable request.
