Front panel connectors P5Q Pro
1 Mar 2007
Portsmouth
Morning all, can someone help me with wiring up my front panel connectors please, iam using the Lian PC7 case. Ive plugged what I think is right onto the board but the front USB ports arent working.
Did the USB connects come in one single block or were there lots of individual wires? If the latter I wouldn't plug them in, too much hassle!
It will normally say how in the motherboard manual.
Yer it does but on the mobo it doesnt have a description on what pin is what.
Both mate, you also get ASUS Q-Connector's which is basically the block which ive already got(you put the little wires into the ASUS Q-Connector, then plug onto your mobo.
long shot but make sure they are enabled in the bios? try another slot? try a low power USB device like a mouse for testing or something.
Tried my iPhone and that didnt work, will check the BIOS
