- 26 Nov 2009
Hi guys. Do you own a front road bike light to view dark unlit roads which you are happy with and can wholeheartedly recommend?
Cateye Volt series are recommended, Leyzene as well. I run a Moon Xp780 superceded now by some other model. Plenty enough light for road use in fact more than enough even on medium power. All those chinese cree front ights purporting to have a gazzilion lumens are bright alright but blind every other f....r on the road and generally are of crap quality as well, been there and have the t shirt.
The old moto you pay cheap you pay twice, certainly my experience with the chinese lights. However others will say different which is also fine. Don`t think you need anything stupidly bright for even dark country lanes, ruins your own night vision anyway.
Here in Stoke I have lots of incidents with cars taking no notice of me with my normal Cateye light.
Since I've had the Smart 700 above I've noticed a difference already with how I'm treated.
TBH you are probably blinding the driver to the point they can barely see anything. This is very common on my commute into Edinburgh just now with a large number of cyclists using head torches and miss angled bar lights, it is like a car driving towards you with the high beams on. (I am a keen cyclist and also commute but I make sure my lights are at a suitable angle)
You know what? I really don't care, they can now see I'm on the road where before with my Cateye they would just pull out or in front of me as though I wasn't there.
To be honest it would not matter a jot how visible you are there are poor drivers on the road end off but there are also some right numpty cyclists, just glad I don`t cycle in city centres !
I do try my best not to blind drivers with my Cree (angled down, different lens fitted) but let's face it, the majority of new cars come with ludicrously blinding HID lights fitted as standard that are seemingly legal. A 4x4 behind you on the motorway at night usually makes your wing mirrors useless. In the face of that I'm not that bothered if drivers find the glare a bit much.
Totally useless IMO!
This is pretty much my approach. I've taken to shouting at cyclists on the floop that angle their blinding lights upwards though...
