Hi guy's
Bought an SSD couple of months back every thing worked fine until it came to a fresh install of windows 7 which is 100% genuine as it wos bought on Friday from Ocuk.
On installing the Os i did a quick format for a clean install, start the install procedure which resulted in the Pc shutting it self down.
So i fired up the lappy to do some research on what the problem is or could be.
The only solution i could find was to erase it with the Samsung Magician software that came with the hardware.
So i had to install a fresh copy of windows to another HDD just to install the Samsung software to secure erase the SSD, as my laptop didn't pick up the SSD.
Windows (fresh install) picked up the SSD in the Magician software, i started the procedure to erase but get some error of the drive been in a frozen state.
Its says follow the steps below to sort out the problem,
basically all it told me to do was start the erase an if its frozen remove the power cable to the SSD for a couple of seconds then put it back.
Every time i disconnected the drive i would get different errors/problems the first one resulted in the Pc restarting it self an followed by 2 BSOD.
It totally messed up all of mobo settings which was a nightmare to sort out.
Now basically i can't do a thing with the SSD, the SSD was bought roughly 2-3 months ago.
I still have the receipts from purchase as well.
Ive posted in Customer Service but i thought id also post here for any ideas, Secure Erase with the supplied software is a no no its kills my rig.
Cheers Crow
Cheers Crow
