FS9 people help!
Permabanned
31 May 2005
South Yorkshire
After having to reinstall XP Pro - and the whole job lot of FS9 goodies - nothing takes off from Manchester 24R (I know it's 23 now - maybe that's the problem?). All my traffic just taxis into position and holds... forever.
24L works fine, as do the 6's. Every other airport despatches and receives aircraft fine - just this one runway at EGCC.
Never had this problem before, I use EGCC as my base and more often than not FS9 uses 24R as it's departure runway, so I'm a bit puzzled as to why this has happened.
Screen :)
Whilst I don't know the answer to your question maybe if you swung *** wind direction 180degrees another runway would become the 'active' one and hopefully the planes would take off.
Unfortunately this isn't a fix just a work around!
No new AFCAD's no.
The only thing I have done is installed the latest AIRAC cycle for PMDG, 0709. I know that contains the new EGCC runway designations but (as far as I know) that's just for the FMC and updated SID/STARs.
I'm still at a loss.
