FTP Problems!!! Help
11 Aug 2005
UK
I'm looking to upload a website that i have recently created but i'm having a few difficulties. The host is BT (Connect) (Business) and i normally login to their website and use their ftp access but its really slow and totally useless.
So, i thought it would be easier to use a third party ftp software solution. I downloaded SmartFTP and gave it a go but i can't get connected no matter what i do.
I think the problem is the host name as i've entered the login and password correctly! I don't know what to enter here as i've tried a few combinations without any luck, such as:
ftp.mysite.com
ftp.btconnect.com
The message displays as: 'Unable to resolve host name'
Can anyone help or shed any light on my problem?
Thanks
*p.s - is it ok to have images within an images folder and then place your jpegs within that subfolder?
i.e:
- top level of file structure
- images folder
- jpegs folder
Thanks for that marc2003, its good to know - however, i managed to get it to work without that address.
It turns out that: ftp.mysite.com is correct as when i tried it at home it worked. Must be the security on the servers within my workplace that was blocking it from connecting.
Also, it looks that having images within a multiple folder structure doesn't work, i had to put all my jpegs/gifs/etc within one images folder.
well that depends on how you build your website? :confused: you'd have to specify the path to the file in your html eg
Code:
<img src="images/jpg/pic.jpg" />
or am i completely missing the point... :p
Thats exactly what i thought. I had it set-up as you have suggested and it worked while previewing locally but as soon as i uploaded the info it didn't work.
Could be something wrong at my end but i would have thought that if it previews ok, it should work when uploaded!!
You must have something wrong. Make sure you're using <img src="folder/folder/image.jpg" /> and not <img="/folder/folder/image.jpg" />
