FTP problems
Permabanned
18 Oct 2002
Lost!
I'm using smartFTP, trying to upload a newly modified site based on a shopping cart system however it sets off fine uploading the files but then will just stop, saying server timed out, refused connection or somthing else.
A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
Why is it that i have to try 2/3/4 or more times to get all the files up onto the server?
Add SmartFTP to the exception list on windows firewall, see if this helps. Also make sure programs are blocking the program.
Thing is, it cant be the firewall as the transfer starts ok, and will do several hundred files/folders and then die, i've even tried it with firewall disabled and it still does it :mad:
Seems to have worked fine using ws_ftp, i also tried cuteFTP and that failed in the same way that smartFTP did...
Very odd, but at least one worked so i can finish off my work properly :)
where are you uploading too ? ....... a remote server ? it could be the actual server itself.
