- 18 Oct 2002
- Tyne & Wear
Quick question, My exchange is due to be enabled some time next year for FTTC. I was on the BT wholesale checker and as I get my phone through sky I used the post code checker and got this:
Great I thought, looks like I can get FTTC when my exchange is enabled.
However, I tried it with the address checker and the bit above highlighted in bold was not there. Does this mean my cabinet will not be upgraded?
Thanks in advance
Your exchange is ADSL enabled, and our initial check on your postcode indicates that your line should be able to have an ADSL broadband service that provides a fixed line speed up to 1Mbps. However due to the length of your line the 1Mbps service may require an engineer visit who will, where possible, supply the broadband service.
Our check also indicates that your line currently supports an estimated ADSL Max broadband line speed of 2Mbps; typically the line speed would range between 1Mbps and 3.5Mbps.
Our check also indicates that your line currently supports an estimated ADSL2+ broadband line speed of 2.5Mbps; typically the line speed would range between 1Mbps and 4Mbps.
Our test also indicates that your line currently supports a fibre technology with an estimated WBC FTTC Broadband where consumers have received downstream line speed between 28.7 to 31.5 Mbps and upstream line speed between 6.2 to 7.2 Mbps.
The actual stable line speed supportable will be determined during the first 10 days of use. This speed may change over time, to ensure line stability is maintained.
Thank you for your interest.
Thanks in advance
