 - 29 Dec 2010
 - Wiltshire
Greetings Folks
Quick one to all the other fibre users to see if you can help with this one.
Had my EE Fibre installed today and its ok so far.
Sync speed is more then i was told i would get, So that's a bonus.
But the throughput is bad.
Once connected the Modem got 79.9 / 20Mbps sync yet speed tests never above 35Mbps.
I have Unlocked the Openreach Modem and all stats are great.
I have tested the speed using a number of sites, Speedtester.bt.com, Speedtest.net, Thinkbroadband.
All showing speeds from 25 - 35Mbps with cable.
I also have a Samknows wihte box that is connected directly to the router and this is still only showing 38.18Mbps
My ip profile is 77.43Mbps
Do you think my throughput will get better of time?
I am also going to get on to EE as the engineer refused to install the data extension kit.
Kind Regards
Steven
		Code:
	Status: Showtime
Retrain Reason: 0
Max:    Upstream rate = 29437 Kbps, Downstream rate = 95328 Kbps
Path:   0, Upstream rate = 20000 Kbps, Downstream rate = 79999 Kbps
Discovery Phase (Initial) Band Plan
US: (0,95) (868,1207) (1972,2783)
DS: (32,859) (1216,1963) (2792,3959)
Medley Phase (Final) Band Plan
       VDSL Port Details       Upstream        Downstream
Attainable Net Data Rate:      29437 kbps         95328 kbps
Actual Aggregate Tx Power:        6.6 dBm          13.0 dBm
  VDSL Band Status        U0      U1      U2      U3      D1      D2      D3
  Line Attenuation(dB):  3.9     18.4    27.5     N/A    9.8     22.2    34.0
Signal Attenuation(dB):  3.9     17.6    26.5     N/A    9.8     22.2    34.0
        SNR Margin(dB):  14.8    15.0    15.1     N/A    10.2    10.2    10.3
         TX Power(dBm): -8.4    -27.0    6.4      N/A    9.6     7.6     7.1
		Code:
	Status: Showtime
Retrain Reason: 0
Link Power State:       L0
Mode:                   VDSL2 Annex B
VDSL2 Profile:          Profile 17a
TPS-TC:                 PTM Mode
Trellis:                U:ON /D:ON
Line Status:            No Defect
Training Status:        Showtime
                Down            Up
SNR (dB):        10.2            15.1
Attn(dB):        0.0             0.0
Pwr(dBm):        13.0            6.6
                        VDSL2 framing
                        Path 0
B:              239             237
M:              1               1
T:              23              45
R:              0               16
S:              0.0955          0.3782
L:              20107           5373
D:              1               1
I:              240             127
N:              240             254
                        Counters
                        Path 0
OHF:            367072          141803
OHFErr:         1               0
RS:             0               2084687
RSCorr:         0               0
RSUnCorr:       0               0
                        Path 0
HEC:            0               0
OCD:            0               0
LCD:            0               0
Total Cells:    93341180                0
Data Cells:     1653            0
Drop Cells:     0
Bit Errors:     0               0
ES:             1               0
SES:            0               0
UAS:            17              17
AS:             604
                        Path 0
INP:            0.00            0.00
PER:            1.64            4.25
delay:          0.00            0.00
OR:             116.56          60.17
Bitswap:        0               1
Kind Regards
Steven
