FTTP Router Help
16 Jan 2006
Internet
Am just checking, with FTTP - you already have the equipment from bt in the house, all you need to do then is add a router with a Wan port? am i correct? i am looking to add a draytek to a FTTP connection just want to check which Draytek router to get.
Thanks in advance.
FTTP terminates in an ONT which has a standard RJ45 port, so yes, you need a router with an RJ45 WAN port, not a modem. As to Draytek, it's certainly an option, but other options exist.
