Having previously tried Diesel Redex which the mechanic described as Cat's Urine its clear to me that some additives work and others don't.
I need to find out exactly what he put in it now.
i havnt been able to find forte anywhere...
Redex for petrol seems to work if fed in direct at the fuel filter
Annoying to try an hear it through the music, but there's a couple of quiet spots.
You can get better powergains for free... simply clean your air filter every month or two rather than at every service interval. A dirty air filter is often overlooked on cars that are running lumpy or similar problems.
# Cleans injectors and pump and keeps them clean
# Prevents deposit formation on valves, in the intake manifold and in the combustion chambers
# Improves cold starting properties
# Prevents irregular idling and stumbling when accelerating
# Restores injector spray pattern
# Lubricates injectors, valves, pump and upper cylinder area
# Improves combustion and engine performance
# Protects the fuel system against rust and corrosion
# Maintains CO and HC values at a minimum level
# Prolongs the lifetime of the injection system
