fuel stolen
considered a thin bit so when they are drilling so they can drill into the tank but when they spark the metal.... job done... ;)
ever tried to drill a stainless steel sheet with a normal drilla nd drill bit, they'd be there till the point you drive to work in the morning.
I like the hump idea very clever, only issue is if you want to work on the car
Move it further down the drive obviously
Unless your drive is so short it only just fits on of course.
I theorise that it would be possible to access the tank from the other side of the vehicle. Possibly by positioning oneself underneath the vehicle.
True, not as easy as next door, or the ones on the street though. Try and keep it less easy for them than others...
exactly. that's why mine was got at.
plastic tank(well not metal), easy to access, not much chance of passers-by seeing, out of view of houses.....
