Fugliest Case Manu ever?
No way near as bad as that X-Blade case..
eek.
Erm I loved all there cases :):):)
The flash animations were wicked too, id glady buy there products if Ocuk had em will make funky PCs.
Could proberly run the the entire PC passive and just have one 36cm Case fan on the side to exhaust any hot air out ;)
In fact may give that a try in my next build ;)
give us lots of pics when you do get the build going, now if only delta makes 360mm fans :D
A tad dangerous. :eek:
I thought Xclio were bad but after watching the flash animations on their website, I'm not sure whether to laugh or cringe. Who Can Give Me Helps. Is this for real? :p
On another note, I wonder how those XClio PSU's would do if they were pushed to their rated power output.
probably the same way a Q-tec would react:D
a 360mm delta would either cause a perfect vacuum in the case if it was a out-take fan or cause the case to explode due to the amount of air it would suck in if it was an intake, although neither would be a problem as the noise would kill you anyway :D
That case may be ugly but their whole range may redeem it - just dont see the same with xlio...
ps3ud0 :cool:
people must buy them otherwise the company wouldn't make such 'orrible cases. the word that springs to mid who'd like these is "chav"
there the kinda case you see in the windows of high street indipendant PC shops. The kind of people who will give your PC a health check by charging you £50 to run scandisk, and still tell people that every problem they have needs a new mobo at £200, then you will have to upgrade all your other components aswell.
I didn't think they looked that bad. :confused:
I wouldn't want one... but i'd rather take one of them than an Antex P182, maybe this man-flu i'v picked up has warped my taste. :(
I was in OcUK yesterday afternoon and they sold 3 of those 36cm fan things in 20 minutes. Incredible.
Its called people with good taste ;)
No - It's called marketing to the lowest common denominator. But ask yourself this. When it's rumbling away like a buzz-saw and your PC still doesn't run cool - Who will give you helps?
