EDIT: Oh and make sure it's SATA
Would that give better performance than a single 4870?If you are going for a 24" monitor, you may want to consider 2 x 4850 crossfire with that board.
I think I'm going to go with the E8400, although the Q6600 seems interesting.If you are ocing, get the cheapest e8*00, if not the e8600. In fact, I would probably recommend the Q9550.
Slightly over but a much better system.
especially as you are doing cad you want quad. Apart from gfx card will be totally silent.
DDR2 RAM in a DDR3 board?
Also, go dual core for gaming. And stick to a 24" screen, better to have quality rather than size!
