- 18 May 2010
Hi,
I am well confused.
Just changed from a 290X to a Fury Nitro, I have FreeSync enabled and on latest drivers
Loaded up BF4 and for a minute I was enjoying higher FPS at the same settings which is exactly what I wanted and then boom, FPS drops into the 40's and 50's with a noticeable stutter and continues to do this for the next hour every few minutes
Its almost as if FreeSync isnt working or the card is throttling, it hit 75C after 20 mins or so and I have a well cooled case
Used DDU and reinstalled, same problem. Anyone else had this issue and managed to sort it or do I have a dodgy card?
I have an 8350 @ 4.2GHZ - No issues with the 290X and the same CPU
Thanks
I am well confused.
Thanks
