Fury X Pump
4 Jul 2015
Harwich
The built in water pump has failed on my Fury X. It is just over 3 years old, is it possible to get this fixed or a replacement part, as it is annoying that there is nothing wrong with the card itself,
Bin it and get an NVidia GPU. Best thing to do really.
Begone troll.
What is the card manufacturer and purchase date? Some have some long warranties others not.
Do you have the AIO radiator with the water tubes facing down or up? (the correct position should be vertical with tubes facing down)
Do you have custom waterloop or one using EK MLC or Predator? If so buy a waterblock (bykski makes ones still), QDC connectors and distilled water (Predator) or the new cryofluid (MLC) to top up.
Otherwise if the card is sound sell it. Someone might want to watercool it as is a great card still.
Also there is option to try get the Sapphire TriX FuryX air heatsink, or some AIO you can fit on it.
:D
A nano heatsink should work as well considering its the same PCB.
Indeed and I have one at home, but would it work with the furyX VRM positioning? if so I could give it for free to the OP assuming he pays the postage
Should do i would think, if you can find pics of both cards pcb's that'll give a better idea.
Having seen pics I do not believe it covers all VRMS :(
https://www.techpowerup.com/reviews/AMD/R9_Nano/images/front.jpg
https://images.anandtech.com/doci/9621/R9_Nano_Straight_On_Back_Thermal_RGB_5inch_crop.jpg
** Do Not Hotlink images **
Begone troll.
Easy tiger, I work with the guy and told him to ask on here if anyone had any advice. I have built most of his systems and advised him to go for the price/performance cards (hence he is still on a Fury X). Just the same banter on here as I have with him at work.
ahh the pump dying :/ its a known problem with those cards that occurs when a PC is built by a numpty, who put the system together?
