Well i introduced my self in the new members section and mentioned there that i will be starting a new build to allow me to play games like BF3 , MW3 and a few more FPS.
So i hope this list sounds like it is up to the job i am aiming for.
this is my list :-
MOBO - ASUS P8H61 - ML E
CPU - i5 2300 2.8GHz socket 1155
OS - Windows 7 home premium 64 bit
SSD - dedicated to Windows
and thinking about a second SSD for games and keeping my old HDD for picture storage and music. once i checked if it will fit new mobo
PSU i will be looking at 750watt or 800watt possibly
Memory - will be using 8GB of DDR3 at 1333MHz
GPU - i am looking at NVIDIA GTX 550Ti 1024MB GDDR5
I will need to check if i can fit all of this into my current case which was sourced from an other site a good few years back and currently houses an Asus P5N73 - CM which is also an uATX 9.6 inch x 8.4 inch ( 24.5 cm x 21.3 cm ).
And much further down the line i will be looking for an HD LED monitor that has to be wall mountable , as the monitor i have at the moment is up on the wall.
this is my list :-
. i might have a look at modular ones then as i dont plan in using a lot of items. and i have been reading up that a lot of cables can have an effect on air flow.
