Fuzzyness cured by changing to same settings
18 May 2004
Lincoln, Uk
Just wondered if anyone else had expierenced anything like this. I have a dual monitor setup with two older viewsonic screens, actually older might be an understatement...!
Anyway over recent days noticed the RHS one was experiencing a fuzzyness that the LHS one was not, this was most noticeable on text which appeared thicker and the edges blurred rather than sharp. The screens were both being run at their native resolutions, looking online suggested running the colour calibration thing in Windows display settings, this failed to cure it. In the end I changed the resolution to the wrong one, confirmed it, and then changed it back to the right one and the issue went way, so in effect nothing has changed overall.
The machine gets shut down and powered off over night, so its not simply a case that a reboot would have fixed it.
I'm guessing its likely to be some bug in display drivers, windows, or the mitor firmware, just interested to see if anyone else had seen the same?
