Caporegime
- 11 Mar 2005
- Leafy Cheshire
Quick Summary
FWD car - Tighter country road corners around 40 - 50mph, mid corner (around the apex), steady or no throttle, not forcing any weight shift and the back end either wants to break away, does break away or the rear end feels very nervous during the corner and you can feel a slight weight shift going on at the rear.
What could it be?
Detailed
Over the past week my cars decided it would much rather oversteer than understeer, i noticed this last week whilst following another car into a tight corner, the road was damp but i know the corner very well, adjusted my speed to match the conditions but around the apex of the corner the back end broke free and i slid round the corner reasonably sideways.
I put the above down to the damp road conditions but i was a little shocked, roll on yesterday was on the way back home following a classic impreza, dry road this time same sort of corner (Large roundabout style stuff) about apex and i could feel the backend wanted to brake away, just been doing some testing and the car feels very nervous at the rear.
Now i can't hear any clunking (so to speak) i think its just by backbox knocking on the rear valance, i have new Sessantas on the rear (1k old) pressures are correct, i noticed a few weeks back whilst dropping the car off the gravel section of my drive that the rear bounced a little more than expected, just done a bounce test and i'm not sure on the results.
So my question is would leaking rear shocks cause this sort of oversteer situation since they can't damp the loading on the rear causing the backend to break away?
Little confused by this tbh, never had a tailend happy fwd car before and this car deffo wasn't till a week ago.
What could it be?
Detailed
