Vegeta said:????
The AMD equivalent to a FX55 is a AMD FX55?
gamer98 said:yup i am a AMD fanboy to i got £330 to get new ram and CPU n i hav found a FX 55 4 £270 so im torn between both
I am mainly a Gamer so will the performance be better on a FX ?![]()
Solouko said:yeah you mean intel equivilent dont you?
or do you mean the none FX chip like athlon os sempron.. or opteron, because there is no equivilent for either.. the FX 55 is pretty unique... i dont think any single core intell chip can match itbut i'm the wrong person to ask cause i'm an AMD fanboy
Thing said:The 3500 is both slower and has a worse core than the FX55.
Plus the FX55 has an unlocked multiplier so you can overclock it easier in the future as games go up another notch.
The only equivalent to the FX55 is the FX60 which is basically a dual-core FX55 but stupidly expensive.
