- 6 Aug 2009
- Wales
Hi 8pack,
I'm after a little advice on overclocking my system.
I currently have an AMD FX4100 on an ASUS M5A99X motherboard ( i know the cpu it's far from the best) but it was cheap and does the job just about until i Haswell arrives and i swap over.
I'm not very clued up on overclocking, i understand the basics behind it all but that's about it, plus, my motherboard has so many options when it comes to overclocking i feel a little overwhelmed tbh.
So far I've managed 4.6 @1.4volts with temps around 60c.
The only problem is that it's not 100% stable and i get crashes in bf3,
i don't really run benchmarking/stability tests like prime etc, i prefer to just trying playing games, bf3 mostly as i get 100% usage most of the time on both the cpu and my gpus. maybe this is where i'm going wrong by not using prime etc?
I'd really like to get it stable at 4.6 so any info/help at all would be really appreciated.
Incase it helps, here's my full specs
ASUS M5a99x Evo 990x motherboard
AMD FX4100 (Arctic freezer 13 cooler)
ATi 6870s in crossfire
12gb Corsair vengenace LP (DRR3 1600mhz)
Many thanks
Davy
Many thanks
Davy
