G.Skill DDR3 wont run at stock 1600mhz speeds...
8 Jan 2009
North East
Hi all, just recently got around to building my pc up, been running it for a day or so now at stock speeds to test stability.
Just lately tried overclocking my cpu, my ram: http://www.overclockers.co.uk/showproduct.php?prodid=MY-042-GS wont run past 1333mhz, even though its supposed to operate at 1600mhz.
So therefore, if i overclock my cpu, even from 2.83ghz to say 3ghz and the memory speed goes over, say 1410mhz for arguments sake, windows locks up and things. To overclock my cpu (so far 3.2ghz) i need to keep my memory at 1333mhz or below.
Any ideas whats wrong? Spec is in sig.
I must add the motherboard states DDR3 memory can be overclocked to 2000mhz, im not sure what safe ram volts to use if this is what i have to do.
Thanks
Have you enabled XMP - I don't believe this GSkill RAM has the 1600 settings in SPD, just 1333.
So my guess is that if you haven't enabled XMP then it will just be trying to use the 1333 settings which may be too tight as you increase the frequency.
Cheers,
Nigel
so i enable this XMP?
never heard of it before, first ddr3 set.
cheers mate
edit: tried with XMP enabled, it showed as 1600mhz but wouldnt boot with my overclock.
XMP settings were:
Auto (this is what was set originally)
Profile1
Disabled
That's not good.
I had to return some GSkill - the CL7 version of what you have because I couldn't get it to run at CL7 but it would run okay at CL8 and CL9.
My problems is that my system is AMD, so I can't read XMP and when I asked GSkill Tech Support for help they just said it was only designed for Intel P55.
Cheers,
Nigel
What voltages have you set your RAM to?
I'm guessing as the board you have is fairly old now, that the G-Skill will not be on the QVL. Try putting it to 1.65v in the bios, as this is what it is rated at.
After a quick google I found this, the tester here states he had a bit of a mare getting any sort of overclock on the RAM, and ended up having to put 2.0v through it.
Overclocking the CPU was as easy as making a few clicks here and there followed by a restart. It wasn't until I moved on to overclock the RAM that I experienced my first difficulties. In fact, after a whole lot of time spent on the subject, I found it almost impossible to overclock any number of the dozen or more DDR3 system memory kits I had at my disposal. If it wasn't a tricky combination of system memory multipliers matched to obscure MCH frequency latch preferences, it was the unfamiliar DRAM voltage variables. At the end of a long week filled with trail and error, I finally found myself capable of getting at least one memory kit to operate at the 1800 MHz it was designed for.
EDIT: Thought you were going to go for core i5 anyway Toon :p;)
Ok thanks for the link, i set it at 1.66v in the bios, i currently have my cpu overclocked to 3.9ghz (havnt tested stability yet) and my ram is running over the 1333mhz, something like 1480mhz.
--yeah i was looking at i5 mate, couldnt find any decent heatsinks for it - also i read on this forum some of the pins on the i5 socket are burning from the overclocking.
Also if i sold this Q9550 which is new, i would have lost a bit of money, so it stayed :D
edit: coupe, have you seen my cable management skills? http://forums.overclockers.co.uk/showthread.php?t=18069636 :D
