G-Skill Memory HELP!
17 May 2012
I'm looking at G-Skill RAM for my new system. I want the blue ones to match the colour of my motherboard. I need two 4GB sticks but I can only find the blue G-Skill memory in two 2GB sticks. Any help?
G-Skill 4GB (2x2GB) DDR3 1333Mhz Ripjaws Memory Kit CL8 (8-8-8-21) 1.5V
Unless im mistaken, his mobo doesnt support 1600mhz ram? It will downclock to 1333 but isnt it cheaper to go for standard 1333mhz ram?
On looking prices are a tad lower at 1333mhz.
If you consider not having G-skill id suggest this
Its low profile so you can fit monster cpu coolers in there.
YOUR BASKET
1 x Kingston HyperX Blu 8GB (2x4GB) DDR3 PC3-10666C9 1333MHz Dual Channel Kit (KHX1333C9D3B1K2/8G) £41.99
Total : £45.90 (includes shipping : £3.26).
The memory will run at lower speed, as the price difference is extremely minimal in some cases the 1600mhz can be cheaper you, might as well get the 1600mhz.
I don't want 1600Mhz modules. That is why I like G-Skill, because they offer 1333Mhz modules.
They will work on your system, as mentioned there is virtually no price difference, sadly we can't mention were to get the Gskill from due to forum rules.
But as you want 1333mhz modules what about the Kingston posted above.
I like the design of G-Skill RAM.
