- 11 Dec 2009
hi. bought a G.Skill Ripjaw 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit for here and in installed it and everything is runiing ine , but i looked at cpu-z and went to check on the speed of my ram, and it says its running at 667MHz instead of 1600MHz, am i missing something or am i just not reading it properly? Do i have to set it in the bios? If it helps my motherboard is ASUS M4A79XTD EVO.
http://i45.tinypic.com/rk6fci.png
Thanks
Thanks
its stupid tho that the supported ram and supported speed for the motherboard does not automaticly apply it maximun speed...
